Polynomial root finding over local rings and application to error correcting codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Algebra in Engineering, Communication and Computing Année : 2013
This article is devoted to algorithms for computing all the roots of a univariate polynomial with coefficients in a complete commutative Noetherian unramified regular local domain, which are given to a fixed common finite precision. We study the cost of our algorithms, discuss their practical performances, and apply our results to the Guruswami and Sudan list decoding algorithm over Galois rings.
main30.pdf (487.69 Ko) Télécharger le fichier
hal-00642075 , version 1 (17-11-2011)
hal-00642075 , version 2 (20-12-2013)
Jérémy Berthomieu, Grégoire Lecerf, Guillaume Quintin. Polynomial root finding over local rings and application to error correcting codes. Applicable Algebra in Engineering, Communication and Computing, 2013, 24 (6), pp.413-443. ⟨10.1007/s00200-013-0200-5⟩. ⟨hal-00642075v1⟩
524 Consultations
928 Téléchargements
