Sufficient Completeness Verification for Conditional and Constrained Term Rewriting Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Logic Année : 2012
We present a procedure for checking sufficient completeness of conditional and constrained term rewriting systems containing axioms for constructors which may be constrained (by e.g. equalities, disequalities, ordering, membership...). Such axioms allow to specify complex data structures like e.g. sets, sorted lists or powerlists. Our approach is integrated into a framework for inductive theorem proving based on tree grammars with constraints, a formalism which permits an exact representation of languages of ground constructor terms in normal form. The procedure is presented by an inference system which is shown sound and complete. A precondition of one inference of this system refers to a (undecidable) property called strong ground reducibility which is discharged to the above inductive theorem proving system. We have successfully applied our method to several examples, yielding readable proofs and, in case of negative answer, a counter-example suggesting how to complete the specification. Moreover, we show that it is a decision procedure when the TRS is unconditional but constrained, for an expressive class of constrained constructor axioms.
completeness-long.pdf (272.57 Ko) Télécharger le fichier
hal-00643136 , version 1 (21-11-2011)
Adel Bouhoula, Florent Jacquemard. Sufficient Completeness Verification for Conditional and Constrained Term Rewriting Systems. Journal of Applied Logic, 2012, 10 (1), pp.127-143. ⟨10.1016/j.jal.2011.09.001⟩. ⟨hal-00643136⟩
145 Consultations
268 Téléchargements
