self-configuration of Home Absraction Layer via sensors and actuators network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a mechanism and system for the identi cation, self-con guration, monitoring and control of non-networked home devices through a shared backplane of networked sensors and actuators. The resulting generic home abstraction layer interfaces to all kinds of physical entities of the home through a software proxy, as if they were state-of-the-art networked devices. The matching of the entities being discovered in the home/building environment to known semi-generic models is performed by iterative approximation. The architecture and OSGi-based implementation of this system is described. Examples are provided for typical home appliances and other subsystems of the home/building that may be dealt with in a similar way.
2011-AmI.pdf (221.17 Ko) Télécharger le fichier
hal-00643940 , version 1 (23-11-2011)
  • HAL Id : hal-00643940 , version 1
Zheng Hu, Gilles Privat, Stéphane Frénot, Bernard Tourancheau. self-configuration of Home Absraction Layer via sensors and actuators network. 2nd International Joint Conference on Ambient Intelligence, Nov 2011, Amsterdam, Netherlands. ⟨hal-00643940⟩
397 Consultations
197 Téléchargements
