Dynamic Arc-Flags in Road Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we introduce a new data structure, named Road-Signs, which allows us to efficiently update the Arc-Flags of a graph in a dynamic scenario. Road-Signs can be used to compute Arc-Flags, can be efficiently updated and do not require large space consumption for many real-world graphs like, e.g., graphs arising from road networks. In detail, we define an algorithm to preprocess Road-Signs and an algorithm to update them each time that a weight increase operation occurs on an edge of the network. We also experimentally analyze the proposed algorithms in real-world road networks showing that they yields a significant speed-up in the updating phase of Arc-Flags, at the cost of a very small space and time overhead in the preprocessing phase.
RoadSigns.pdf (353.38 Ko) Télécharger le fichier
hal-00644054 , version 1 (23-11-2011)
Gianlorenzo d'Angelo, Daniele Frigioni, Camillo Vitale. Dynamic Arc-Flags in Road Networks. 10th International Symposium, SEA 2011, May 2011, Kolimpari, Chania, Crete, Greece. pp.88-99, ⟨10.1007/978-3-642-20662-7_8⟩. ⟨hal-00644054⟩
239 Consultations
836 Téléchargements
