Hybrid Contract Checking via Symbolic Simplification
Program errors are hard to detect or prove absent. Allowing programmers to write formal and precise specifications, especially in the form of contracts, is a popular approach to program verification and error discovery. We formalize and implement a hybrid contract checker, that is static checking followed by dynamic checking, for a subset of OCaml. The key technique we use is symbolic simplification, which makes integrating static and dynamic contract checking easy and effective. Our technique statically verifies that a function either satisfies its contract or blames the function violating the contract. When a contract satisfaction is undecidable, it leaves residual code for dynamic contract checking.
Langage de programmation [cs.PL]
