A robust parametric active contour based on Fourier descriptors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an optimal parametric active contour method based on Fourier descriptors to detect and track a contour from a sequence of images in real-time. The advan- tage of this approach is that not only convex but also concave contours can be considered. We also propose a method to ini- tialize the active contour using only three user's clicks in the first image of the sequence and to automatically re-initialize it when possible topological changes are detected during the tracking. Moreover, the algorithm is implemented on GPU to ensure the real-time tracking performance.
2011_icip_li.pdf (410.87 Ko) Télécharger le fichier
hal-00645326 , version 1 (27-11-2011)
  • HAL Id : hal-00645326 , version 1
Tao Li, Alexandre Krupa, Christophe Collewet. A robust parametric active contour based on Fourier descriptors. IEEE Int. Conf. on Image Processing, ICIP'11, Sep 2011, Bruxelles, Belgium. ⟨hal-00645326⟩
271 Consultations
200 Téléchargements
