Secant varieties to osculating varieties of Veronese embeddings of P^n - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2009
A well known theorem by Alexander-Hirschowitz states that all the higher secant varieties of $V_{n,d}$ (the $d$-uple embedding of $\PP n$) have the expected dimension, with few known exceptions. We study here the same problem for $T_{n,d}$, the tangential variety to $V_{n,d}$, and prove a conjecture, which is the analogous of Alexander-Hirschowitz theorem, for $n\leq 9$. Moreover. we prove that it holds for any $n,d$ if it holds for $d=3$. Then we generalize to the case of $O_{k,n,d}$, the $k$-osculating variety to $V_{n,d}$, proving, for $n=2$, a conjecture that relates the defectivity of $\sigma_s(O_{k,n,d})$ to the Hilbert function of certain sets of fat points in $\PP n$.
OSCU2008.pdf (231.62 Ko) Télécharger le fichier
hal-00645970 , version 1 (28-11-2011)
Alessandra Bernardi, Maria Virgina Catalisano, Alessandro Gimigliano, Monica Idà. Secant varieties to osculating varieties of Veronese embeddings of P^n. Journal of Algebra, 2009, 321 (3), pp.982-1004. ⟨10.1016/j.jalgebra.2008.10.020⟩. ⟨hal-00645970⟩
149 Consultations
142 Téléchargements
