Constraining the Size Growth of the Task Space with Socially Guided Intrinsic Motivation using Demonstrations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an algorithm for learning a highly redundant inverse model in continuous and non-preset environments. Our Socially Guided Intrinsic Motivation by Demonstrations (SGIM-D) algorithm combines the advantages of both social learning and intrinsic motivation, to specialise in a wide range of skills, while lessening its dependence on the teacher. SGIM-D is evaluated on a fishing skill learning experiment.
ijcai11Nguyen.pdf (1.52 Mo) Télécharger le fichier
hal-00645995 , version 1 (29-11-2011)
Sao Mai Nguyen, Adrien Baranes, Pierre-Yves Oudeyer. Constraining the Size Growth of the Task Space with Socially Guided Intrinsic Motivation using Demonstrations.. IJCAI Workshop on Agents Learning Interactively from Human Teachers (ALIHT), 2011, Barcelona, Spain. ⟨hal-00645995⟩
210 Consultations
77 Téléchargements
