Quantitative Multi-Objective Verification for Probabilistic Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a verification framework for analysing multiple quantitative objectives of systems that exhibit both nondeterministic and stochastic behaviour. These systems are modelled as probabilistic automata, enriched with cost or reward structures that capture, for ex- ample, energy usage or performance metrics. Quantitative properties of these models are expressed in a specification language that incorporates probabilistic safety and liveness properties, expected total cost or re- ward, and supports multiple objectives of these types. We propose and implement an efficient verification framework for such properties and then present two distinct applications of it: firstly, controller synthesis subject to multiple quantitative objectives; and, secondly, quantitative compositional verification. The practical applicability of both approaches is illustrated with experimental results from several large case studies.
Informatique
tacas11.pdf (445.5 Ko) Télécharger le fichier
hal-00647055 , version 1 (01-12-2011)
  • HAL Id : hal-00647055 , version 1
Vojtech Forejt, Marta Kwiatkowska, Gethin Norman, David Parker, Hongyang Qu. Quantitative Multi-Objective Verification for Probabilistic Systems. 17th International Conference on Tools and Algorithms for the Construction and Analysis of Systems (TACAS'11), 2011, Saarbrücken, Germany. pp.112--127. ⟨hal-00647055⟩
Collections
CONNECT
74 Consultations
127 Téléchargements
