An Object Tracking in Particle Filtering and Data Association Framework, Using SIFT Features
In this paper, we propose a novel approach for multi-object tracking for video surveillance with a single static camera using particle filtering and data association. The proposed method allows for real-time tracking and deals with the most important challenges: 1) selecting and tracking real objects of interest in noisy environments and 2) managing occlusion. We will consider tracker inputs from classic motion detection (based on background subtraction and clustering). Particle filtering has proven very successful for non-linear and non-Gaussian estimation problems. This article presents SIFT feature tracking in a particle filtering and data association framework. The performance of the proposed algorithm is evaluated on sequences from ETISEO, CAVIAR, ETS2001 and VS-PETS2003 datasets in order to show the improvements relative to the current state-of-the-art.
An_Object_Tracking_in_Particle_Filtering_and_Data_Association_Framework_Using_SIFT_Features.pdf (383.09 Ko)
Télécharger le fichier
