Efficient List-Decoding of Reed-Solomon Codes with the Fundamental Iterative Algorithm
In this paper we propose a new algorithm that solves the Guruswami-Sudan interpolation step for Reed-Solomon codes efficiently. It is a generalization of the Feng-Tzeng approach, the so-called fundamental iterative algorithm. From the interpolation constraints of the Guruswami-Sudan principle it is well known that an improvement of the decoding radius can only be achieved, if the multiplicity parameter s is smaller than the list size l. The code length is n and our proposed algorithm has a complexity (without asymptotic assumptions) of O(ls4 n2).}, keywords={Feng-Tzeng approach;Guruswami-Sudan interpolation;Reed-Solomon codes;communication complexity;efficient list-decoding;fundamental iterative algorithm;Reed-Solomon codes;communication complexity;decoding;iterative methods;
Origin : Publisher files allowed on an open archive
