Estimating an endpoint with high order moments in the Weibull domain of attraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics and Probability Letters Année : 2012
We present a method for estimating the endpoint of a unidimensional sample when the distribution function belongs to the Weibull-max domain of attraction. The approach relies on transforming the variable of interest and then using high order moments of the positive variable obtained this way. It is assumed that the order of the moments goes to infinity. We give conditions on the rate of divergence to get the weak and strong consistency as well as the asymptotic normality of the estimator. The good performance of the estimator is illustrated on some finite sample situations.
weibull_logratio_final.pdf (227.14 Ko) Télécharger le fichier
hal-00648435 , version 1 (05-12-2011)
hal-00648435 , version 2 (30-11-2012)
  • HAL Id : hal-00648435 , version 1
Stéphane Girard, Armelle Guillou, Gilles Stupfler. Estimating an endpoint with high order moments in the Weibull domain of attraction. Statistics and Probability Letters, 2012, 82, pp.2136-2144. ⟨hal-00648435v1⟩
398 Consultations
208 Téléchargements
