On a Time-Dependent Formulation and an Updated Classification of ATSP Formulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
In this chapter we contextualize, in terms of the ATSP, a recent compact formulation presented in Godinho et al [11] for the time-dependent traveling salesman problem (TDTSP). The previous paper provides one way of viewing the new model, the time-dependent TSP point of view where it is put in evidence how to obtain the new model by tightening the linear programming relaxation of a well known formulation for the TDTSP. In this chapter, we will present the ATSP point of view and will show how to obtain the model by i) enhancing the subproblem arising in the standard multicommodity ow (MCF) model for the ATSP and then ii) by using modelling enhancement techniques. We will compare the linear programming relaxation of the new formulation with the linear programming relaxation of the three compact and non-dominated formulations presented in Oncan et al. [19]. As a result of this comparison we present an updated classication of formulations for the asymmetric traveling salesman problem (ATSP).
ATSP-ProgressinCO.pdf (450 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00648457 , version 1 (05-12-2017)
  • HAL Id : hal-00648457 , version 1
Maria Teresa Godinho, Luís Gouveia, Pierre Pesneau. On a Time-Dependent Formulation and an Updated Classification of ATSP Formulations. Ali Ridha Mahjoub. Progress in Combinatorial Optimization, Wiley, 2011, 9781848212060. ⟨hal-00648457⟩
396 Consultations
197 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
