Regulation of mammalian cell cycle progression in the regenerating liver. - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Journal of Theoretical Biology Year : 2011
The process of cell division in mammalian cells is orchestrated by cell-cycle-dependent oscillations of cyclin protein levels. Cyclin levels are controlled by redundant transcriptional, post-translational and degradation feedback loops. How each of these separate loops contributes to the regulation of the key cell cycle events and to the connection between the G1-S transition and the subsequent mitotic events is under investigation. Here, we present an integrated computational model of the mammalian cell cycle based on the sequential activation of cyclins. We validate the model against experimental data on liver cells (hepatocytes), which undergo one or two rounds of synchronous circadian-clock gated cell divisions during liver regeneration, after partial hepatectomy (PH). The model exhibits bandpass filter properties that allow the system to ignore strong but transient, or sustained but weak damages after PH. Bifurcation analysis of the model suggests two different threshold mechanisms for the progression of the cell through mitosis. These results are coherent with the notion that the mitotic exit in mammalian cells is bistable, and suggests that Cdc20 homologue 1 (Cdh1) is an important regulator of mitosis. Regulation by Cdh1 also explains the observed G2/M phase prolongation after hepatocyte growth factor (HGF) stimulation during S phase.
jtb_finalreviewed.pdf (390.12 Ko) Télécharger le fichier
Dates and versions
hal-00649211 , version 1 (14-01-2020)
Identifiers
Cite
Anuradha Chauhan, Stephan Lorenzen, Hanspeter Herzel, Samuel Bernard. Regulation of mammalian cell cycle progression in the regenerating liver.. Journal of Theoretical Biology, 2011, 283 (1), pp.103-12. ⟨10.1016/j.jtbi.2011.05.026⟩. ⟨hal-00649211⟩
573 View
126 Download
Share
