Importance Sampling of Probabilistic Contracts in Web Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With web services quality of service (QoS) modeled as random variables, the accuracy of sampled values for precise service level agreements (SLAs) come into question. Samples with lower spread are more accurate for calculating contractual obligations, which is typically not the case for web services QoS. Moreover, the extreme values in case of heavy-tailed distributions (eg. 99.99 percentile) are seldom observed through limited sampling schemes. To improve the accuracy of contracts, we propose the use of variance reduction techniques such as importance sampling. We demonstrate this for contracts involving demand and refuel operations within the Dell supply chain example. Using measured values, efficient forecasting of future deviation of contracts may also be performed. A consequence of this is a more precise definition of sampling, measurement and variance tolerance in SLA declarations.
Web
rare2_ICSOCshort.pdf (195.47 Ko) Télécharger le fichier
hal-00650316 , version 1 (09-12-2011)
Ajay Kattepur. Importance Sampling of Probabilistic Contracts in Web Services. 9th International Conference on Service-Oriented Computing, Dec 2011, Paphos, Cyprus. ⟨10.1007/978-3-642-25535-9_41⟩. ⟨hal-00650316⟩
174 Consultations
177 Téléchargements
