A Graph-matching Kernel for Object Categorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses the problem of category-level image classification. The underlying image model is a graph whose nodes correspond to a dense set of regions, and edges reflect the underlying grid structure of the image and act as springs to guarantee the geometric consistency of nearby regions during matching. A fast approximate algorithm for matching the graphs associated with two images is presented. This algorithm is used to construct a kernel appropriate for SVM-based image classification, and experiments with the Caltech 101, Caltech 256, and Scenes datasets demonstrate performance that matches or exceeds the state of the art for methods using a single type of features.
Fichier non déposé
hal-00650345 , version 1 (09-12-2011)
  • HAL Id : hal-00650345 , version 1
Olivier Duchenne, Armand Joulin, Jean Ponce. A Graph-matching Kernel for Object Categorization. ICCV 2011 - 13th International Conference on Computer Vision, Nov 2011, Barcelona, Spain. pp.1056. ⟨hal-00650345⟩
223 Consultations
0 Téléchargements
