Scikit-learn: Machine Learning in Python - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2011
Olivier Grisel
  • Fonction : Auteur
Mathieu Blondel
  • Fonction : Auteur
Ron Weiss
  • Fonction : Auteur
Vincent Dubourg
  • Fonction : Auteur
  • PersonId : 764251
  • IdRef : 159794714
David Cournapeau
  • Fonction : Auteur
Matthieu Brucher
  • Fonction : Auteur
Matthieu Perrot
  • Fonction : Auteur
Scikit-learn is a Python module integrating a wide range of state-of-the-art machine learning algorithms for medium-scale supervised and unsupervised problems. This package focuses on bringing machine learning to non-specialists using a general-purpose high-level language. Emphasis is put on ease of use, performance, documentation, and API consistency. It has minimal dependencies and is distributed under the simplified BSD license, encouraging its use in both academic and commercial settings. Source code, binaries, and documentation can be downloaded from http://scikit-learn.sourceforge.net.
pedregosa11a.pdf (87.19 Ko) Télécharger le fichier
hal-00650905 , version 1 (02-01-2012)
hal-00650905 , version 2 (02-03-2013)
Fabian Pedregosa, Gaël Varoquaux, Alexandre Gramfort, Vincent Michel, Bertrand Thirion, et al.. Scikit-learn: Machine Learning in Python. Journal of Machine Learning Research, 2011. ⟨hal-00650905v2⟩
8576 Consultations
6242 Téléchargements
