Numerical simulations of electrocardiograms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Muriel Boulakia
Nejib Zemzemi
This chapter presents a concise overview of various mathematical and numerical problems raised by the simulation of electrocardiograms (ECGs). A model for the propagation of the electrical activation in the heart and in the torso is proposed. Some of its mathematical properties are analyzed. This model is not aimed at reproducing the complex phenomena taking place at the microscopic level. It has been devised to produce realistic healthy ECGs, and some pathological ones, with a reasonable level of complexity. It relies on various assumptions that are carefully discussed through their impact on the ECGs. The coupling between the heart and the torso is a critical numerical issue which is addressed. In particular efficient coupling strategies based on explicit algorithms are presented and analyzed. The chapter ends with some preliminary results of a reduced order model based on the Proper Orthogonal Decomposition (POD) method.
Fichier non déposé
hal-00652367 , version 1 (15-12-2011)
  • HAL Id : hal-00652367 , version 1
Muriel Boulakia, Miguel Angel Fernández, Jean-Frédéric Gerbeau, Nejib Zemzemi. Numerical simulations of electrocardiograms. Ambrosi, D. and Quarteroni, A. and Rozza, G. Modeling of Physiological Flows, Springer, pp.77-106, 2011, 978-88-470-1934-8. ⟨hal-00652367⟩
162 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
