On the existence of stationary solutions for some non-Fredholm integro-differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Documenta Mathematica Année : 2011
We show the existence of stationary solutions for some reaction-diffusion type equations in the appropriate H2 spaces using the fixed point technique when the elliptic problem contains second order differential operators with and without Fredholm property.
nfnl-revised.pdf (170.68 Ko) Télécharger le fichier
hal-00653648 , version 1 (19-12-2011)
  • HAL Id : hal-00653648 , version 1
Vitali Vougalter, Vitaly Volpert. On the existence of stationary solutions for some non-Fredholm integro-differential equations. Documenta Mathematica, 2011, 16, pp.561-580. ⟨hal-00653648⟩
380 Consultations
86 Téléchargements
