Computational Algorithm for Some Problems with Variable Geometrical Structure - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Lecture Notes in Computer Science Year : 2011
The work is devoted to the computational algorithm for a problem of plant growth. The plant is represented as a system of connected intervals corresponding to branches. We compute the concentration distributions inside the branches. The originality of the problem is that the geometry of the plant is not a priori given. It evolves in time depending on the concentrations of plant hormones found as a solution of the problem. New branches appear in the process of plant growth. The algorithm is adapted to an arbitrary plant structure and an arbitrary number of branches.
algorithm.pdf (301.64 Ko) Télécharger le fichier
Dates and versions
hal-00653652 , version 1 (19-12-2011)
Identifiers
Cite
Nikolai Bessonov, Vitaly Volpert. Computational Algorithm for Some Problems with Variable Geometrical Structure. Lecture Notes in Computer Science, 2011, 6260/2011, pp.87-102. ⟨10.1007/978-3-642-16236-7_6⟩. ⟨hal-00653652⟩
548 View
185 Download
Share
