Spectrum of some integro-differential operators and stability of travelling waves - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Nonlinear Analysis: Theory, Methods and Applications Year : 2011
Spectral properties of some integro-differential operators on R1 are studied. Characterization of the principal eigenvalue is obtained in terms of the positive eigenfunction. These results are used to prove local and global stability of travelling waves and to find their speed.
int-spectrum15.pdf (239.53 Ko) Télécharger le fichier
Dates and versions
hal-00653653 , version 1 (20-12-2011)
Identifiers
Cite
Arnaud Ducrot, Martine Marion, Vitaly Volpert. Spectrum of some integro-differential operators and stability of travelling waves. Nonlinear Analysis: Theory, Methods and Applications, 2011, 74 (13), pp.4455-4473. ⟨10.1016/j.na.2011.04.009⟩. ⟨hal-00653653⟩
459 View
326 Download
Share
