Properness and Topological Degree for Nonlocal Reaction-Diffusion Operators - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Abstract and Applied Analysis Year : 2011
The paper is devoted to integro-differential operators, which correspond to non-local reaction-diffusion equations considered on the whole axis. Their Fredholm property and properness will be proved. This will allow one to define the topological degree.
int-dif-prop_3_revised.pdf (178.67 Ko) Télécharger le fichier
Dates and versions
hal-00653656 , version 1 (19-12-2011)
Identifiers
  • HAL Id : hal-00653656 , version 1
Cite
Narcisa Apreutesei, Vitaly Volpert. Properness and Topological Degree for Nonlocal Reaction-Diffusion Operators. Abstract and Applied Analysis, 2011, pp.ID 629692. ⟨hal-00653656⟩
184 View
115 Download
Share
