Solvability conditions for some non-Fredholm operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the Edinburgh Mathematical Society Année : 2011
We obtain solvability conditions for some elliptic equations involving non Fredholm operators with the methods of spectral theory and scattering theory for Schrödinger type operators. One of the main results of the work concerns solvability conditions for the equation −Delta u+V (x)u−au = f where a ≥ 0. They are formulated in terms of orthogonality of the function f to the solutions of the homogeneous adjoint equation.
fredholm.pdf (202.18 Ko) Télécharger le fichier
hal-00653658 , version 1 (19-12-2011)
Vitali Vougalter, Vitaly Volpert. Solvability conditions for some non-Fredholm operators. Proceedings of the Edinburgh Mathematical Society, 2011, 54 (1), pp.249-271. ⟨10.1017/S0013091509000236⟩. ⟨hal-00653658⟩
245 Consultations
241 Téléchargements
