A reconstruction of Kulik's table of multiplication (1851) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Kulik's table of multiplication uses the method of quarter-squares and makes it possible to compute products of two numbers whose sum does not exceed 29999. It is reconstructed here.
kulik1851doc.pdf (1.82 Mo) Télécharger le fichier
hal-00654436 , version 1 (21-12-2011)
hal-00654436 , version 2 (06-11-2013)
  • HAL Id : hal-00654436 , version 2
Denis Roegel. A reconstruction of Kulik's table of multiplication (1851). [Research Report] 2013. ⟨hal-00654436v2⟩
588 Consultations
949 Téléchargements
