A reconstruction of the tables of the Shuli Jingyun (1713-1723)
The Shuli Jingyun encyclopaedia, published by the order of Emperor Kangxi, contained a set of tables of logarithms, trigonometrical functions and factors, which have been reconstructed here.
shuli1723intro.pdf (12.07 Mo)
Télécharger le fichier
shuli/shuli1723v1trig1.pdf (2.24 Mo)
shuli/shuli1723v2trig2.pdf (2.34 Mo)
shuli/shuli1723v3fact1.pdf (3.31 Mo)
shuli/shuli1723v4fact2.pdf (3.43 Mo)
shuli/shuli1723v5logn1.pdf (2.77 Mo)
shuli/shuli1723v6logn2.pdf (2.73 Mo)
shuli/shuli1723v7logtrig1.pdf (2.54 Mo)
shuli/shuli1723v8logtrig2.pdf (2.64 Mo)
shuli/skqs-sljy-v01trig1.pdf (1.13 Mo)
shuli/skqs-sljy-v02trig2.pdf (1.32 Mo)
shuli/skqs-sljy-v03trig3.pdf (960.56 Ko)
shuli/skqs-sljy-v04trig4.pdf (1.6 Mo)
shuli/skqs-sljy-v05factors01.pdf (796.84 Ko)
shuli/skqs-sljy-v06factors02.pdf (806.89 Ko)
shuli/skqs-sljy-v07factors03.pdf (820.5 Ko)
shuli/skqs-sljy-v08factors04.pdf (826.49 Ko)
shuli/skqs-sljy-v09factors05.pdf (834.13 Ko)
shuli/skqs-sljy-v10factors06.pdf (835.32 Ko)
shuli/skqs-sljy-v11factors07.pdf (838.91 Ko)
shuli/skqs-sljy-v12factors08.pdf (840.2 Ko)
shuli/skqs-sljy-v13factors09.pdf (842.09 Ko)
shuli/skqs-sljy-v14factors10.pdf (843.58 Ko)
shuli/skqs-sljy-v15lognumbers01.pdf (779.69 Ko)
shuli/skqs-sljy-v16lognumbers02.pdf (775.58 Ko)
shuli/skqs-sljy-v17lognumbers03.pdf (772.01 Ko)
shuli/skqs-sljy-v18lognumbers04.pdf (771.99 Ko)
shuli/skqs-sljy-v19lognumbers05.pdf (769.07 Ko)
shuli/skqs-sljy-v20lognumbers06.pdf (767.92 Ko)
shuli/skqs-sljy-v21lognumbers07.pdf (766.24 Ko)
shuli/skqs-sljy-v22lognumbers08.pdf (763.31 Ko)
shuli/skqs-sljy-v23lognumbers09.pdf (762.59 Ko)
shuli/skqs-sljy-v24lognumbers10.pdf (760.35 Ko)
shuli/skqs-sljy-v25logtrig1.pdf (1.26 Mo)
shuli/skqs-sljy-v26logtrig2.pdf (1.47 Mo)
shuli/skqs-sljy-v27logtrig3.pdf (1.04 Mo)
shuli/skqs-sljy-v28logtrig4.pdf (1.79 Mo)
