Learning Boundary Edges for 3D-Mesh Segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2011
This paper presents a 3D-mesh segmentation algorithm based on a learning approach. A large database of manually segmented 3D-meshes is used to learn a boundary edge function. The function is learned using a classifier which automatically selects from a pool of geometric features the most relevant ones to detect candidate boundary edges. We propose a processing pipeline that produces smooth closed boundaries using this edge function. This pipeline successively selects a set of candidate boundary contours, closes them and optimizes them using a snake movement. Our algorithm was evaluated quantitatively using two different segmentation benchmarks and was shown to outperform most recent algorithms from the state-of-the-art.
CGF-2011-benhabiles-final.pdf (11.78 Mo) Télécharger le fichier
hal-00660740 , version 1 (17-01-2012)
Halim Benhabiles, Guillaume Lavoué, Jean-Philippe Vandeborre, Mohamed Daoudi. Learning Boundary Edges for 3D-Mesh Segmentation. Computer Graphics Forum, 2011, 30 (8), pp.2170-2182. ⟨10.1111/j.1467-8659.2011.01967.x⟩. ⟨hal-00660740⟩
700 Consultations
893 Téléchargements
