Gate automata-driven run-time enforcement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers & Mathematics with Applications Année : 2012
Security and trust represent two different perspectives on the problem of guaranteeing the correct interaction among software components. Gate automata have been proposed as a formalism for the specification of both security and trust policies in the scope of the Security-by-Contract-with- Trust (S×C×T) framework. Indeed, they watch the execution of a target program, possibly modifying its behaviour, and produce a feedback for the trust management system. The level of trust changes the environment settings by dynamically activating/deactivating some of the defined gate automata. The goal of this paper is to present gate automata and to show a gate automatadriven strategy for the run-time enforcement in the S×C×T.
camwa.pdf (119.91 Ko) Télécharger le fichier
hal-00661568 , version 1 (20-01-2012)
  • HAL Id : hal-00661568 , version 1
Ilaria Matteucci, G. Costa. Gate automata-driven run-time enforcement. Computers & Mathematics with Applications, 2012. ⟨hal-00661568⟩
Collections
CONNECT
62 Consultations
84 Téléchargements
