CHOReOS "DynaRoute" scenario specification and requirements analysis (D8.1)
The purpose of this deliverable is to clarify the individual actions that take place among different actors of the "DynaRoute" scenario, as initially described in the DoW. People, services and Smart Things interact with each other synthesizing choreographies throughout the entire sequence of steps that compose the scenario which supports this specific use case of the CHOReOS project. This document also provides the involved in the "DynaRoute" use case domain experts‟ requirements through a detailed requirement analysis. Moreover this deliverable presents an abstract overview of choreographies that take place in use case of "DynaRoute". In the end of this document addressed the methods of the assessment specifications that will be applied in demo and pilot application.
CHOReOSWP08D8.1DynaroutescenariospecificationandrequirementsVA.pdf (7.38 Mo)
Télécharger le fichier
