Active procedures to control the flow past the Ahmed body with a 25° rear window - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Aerodynamics Année : 2011
Ahmed body with a 25 degree rear window is used to represent a simpli ed car geometry. Two and three-dimensional simulations are performed to analyse the flow behaviour around such a vehicle. Sucking and blowing jets or slots are added on the body to control the flow. The results presented show that good drag reductions are achieved for a good choice of the active procedure.
Fichier non déposé
hal-00664963 , version 1 (31-01-2012)
Charles-Henri Bruneau, Emmanuel Creusé, Delphine Depeyras, Patrick Gillieron, Iraj Mortazavi. Active procedures to control the flow past the Ahmed body with a 25° rear window. International Journal of Aerodynamics, 2011, 1 (3/4), pp.299-317. ⟨10.1504/IJAD.2011.038847⟩. ⟨hal-00664963⟩
348 Consultations
0 Téléchargements
