Modeling On and Above a Stereoscopic Multitouch Display - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a semi-immersive environment for conceptual design where virtual mockups are obtained from gestures we aim to get closer to the way people conceive, create and manipulate three-dimensional shapes. We developed on-and-above-the-surface interaction techniques based on asymmetric bimanual interaction for creating and editing 3D models in a stereoscopic environment. Our approach combines hand and nger tracking in the space on and above a multitouch surface. This combination brings forth an alternative design environment where users can seamlessly switch between interacting on the surface or in the space above it to leverage the bene t of both interaction spaces.
3DCHI-Final.pdf (9.86 Mo) Télécharger le fichier
Format : Figure, Image
hal-00670565 , version 1 (15-06-2012)
  • HAL Id : hal-00670565 , version 1
Bruno de Araujo, Géry Casiez, Joaquim Jorge, Martin Hachet. Modeling On and Above a Stereoscopic Multitouch Display. 3DCHI - The 3rd Dimension of CHI, May 2012, Austin, United States. pp.79-86. ⟨hal-00670565⟩
402 Consultations
217 Téléchargements
