Fluctuation of solutions to linear elliptic equations with noisy diffusion coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Partial Differential Equations Année : 2013
We consider a linear elliptic equation in divergence form on a bounded domain (or on $\R^d$) in dimension $d\geq 2$, whose coefficients are perturbed by a stationary noise of correlation length $\e>0$. We give estimates on the fluctuation of the solution in function of the correlation length $\e$ of the noise, both in terms of strong $L^2$ and weak $L^1$ norms. This result can be seen as a quantification of the propagation of uncertainties in linear elliptic partial differential equations.
fluctuations_final.pdf (260.59 Ko) Télécharger le fichier
hal-00674445 , version 1 (27-02-2012)
hal-00674445 , version 2 (20-07-2012)
Antoine Gloria. Fluctuation of solutions to linear elliptic equations with noisy diffusion coefficients. Communications in Partial Differential Equations, 2013, 38 (2), pp.35. ⟨10.1080/03605302.2012.715319⟩. ⟨hal-00674445v2⟩
308 Consultations
324 Téléchargements
