On the Non-linearity of Power Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Designs, Codes and Cryptography Année : 2005
We study the Boolean functions arising from power functions by means of Stickelberger's con- gruences on Gauss sum. We obtain a new criterion for high non-linearity of such boolean functions in terms of permutation polynomials. Finally, a new characteristic property of Gold exponents is given.
pow_func.pdf (129.54 Ko) Télécharger le fichier
hal-00674664 , version 1 (20-03-2012)
Philippe Langevin, Pascal Véron. On the Non-linearity of Power Functions. Designs, Codes and Cryptography, 2005, 37, pp.31-43. ⟨10.1007/s10623-004-3803-9⟩. ⟨hal-00674664⟩
Collections
UNIV-TLN IMATH
86 Consultations
450 Téléchargements
