A Stochastic Gradient Method with an Exponential Convergence Rate for Finite Training Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new stochastic gradient method for optimizing the sum of a finite set of smooth functions, where the sum is strongly convex. While standard stochastic gradient methods converge at sublinear rates for this problem, the proposed method incorporates a memory of previous gradient values in order to achieve a linear convergence rate. In a machine learning context, numerical experiments indicate that the new algorithm can dramatically outperform standard algorithms, both in terms of optimizing the training error and reducing the test error quickly.
sag_arxiv.pdf (587.17 Ko) Télécharger le fichier
hal-00674995 , version 1 (28-02-2012)
hal-00674995 , version 2 (05-07-2012)
hal-00674995 , version 3 (06-07-2012)
hal-00674995 , version 4 (11-03-2013)
Nicolas Le Roux, Mark Schmidt, Francis Bach. A Stochastic Gradient Method with an Exponential Convergence Rate for Finite Training Sets. NIPS'12 - 26 th Annual Conference on Neural Information Processing Systems (2012), 2012, Lake Tahoe, United States. ⟨hal-00674995v4⟩
655 Consultations
5197 Téléchargements
