A Stochastic Gradient Method with an Exponential Convergence Rate for Strongly-Convex Optimization with Finite Training Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We propose a new stochastic gradient method for optimizing the sum of a finite set of smooth functions, where the sum is strongly convex. While standard stochastic gradient methods converge at sublinear rates for this problem, the proposed method incorporates a memory of previous gradient values in order to achieve a linear convergence rate. In a machine learning context, numerical experiments indicate that the new algorithm can dramatically outperform standard algorithms, both in terms of optimizing the training objective and reducing the testing objective quickly.
sag_arxiv.pdf (577.93 Ko) Télécharger le fichier
hal-00674995 , version 1 (28-02-2012)
hal-00674995 , version 2 (05-07-2012)
hal-00674995 , version 3 (06-07-2012)
hal-00674995 , version 4 (11-03-2013)
Nicolas Le Roux, Mark Schmidt, Francis Bach. A Stochastic Gradient Method with an Exponential Convergence Rate for Strongly-Convex Optimization with Finite Training Sets. 2012. ⟨hal-00674995v2⟩
656 Consultations
5213 Téléchargements
