Pairing-based algorithms for jacobians of genus 2 curves with maximal endomorphism ring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Sorina Ionica
Using Galois cohomology, Schmoyer characterizes cryptographic non-trivial self-pairings of the $\ell$-Tate pairing in terms of the action of the Frobenius on the $\ell$-torsion of the Jacobian of a genus 2 curve. We apply similar techniques to study the non-degeneracy of the $\ell$-Tate pairing restrained to subgroups of the $\ell$-torsion which are maximal isotropic with respect to the Weil pairing. First, we deduce a criterion to verify whether the jacobian of a genus 2 curve has maximal endomorphism ring. Secondly, we derive a method to construct horizontal $(\ell,\ell)$-isogenies starting from a jacobian with maximal endomorphism ring.
Draft3.pdf (246.94 Ko) Télécharger le fichier
hal-00675045 , version 1 (29-02-2012)
hal-00675045 , version 2 (28-03-2012)
hal-00675045 , version 3 (20-04-2012)
hal-00675045 , version 4 (02-05-2013)
hal-00675045 , version 5 (30-09-2013)
Sorina Ionica. Pairing-based algorithms for jacobians of genus 2 curves with maximal endomorphism ring. 2012. ⟨hal-00675045v3⟩
627 Consultations
395 Téléchargements
