Multiple Operator-valued Kernel Learning
This paper addresses the problem of learning a finite linear combination of operator-valued kernels. We study this problem in the case of kernel ridge regression for functional responses with a lr-norm constraint on the combination coefficients. We propose a multiple operator-valued kernel learning algorithm based on solving a system of linear operator equations by using a block coordinate descent procedure. We experimentally validate our approach on a functional regression task in the context of finger movement prediction in Brain-Computer Interface (BCI).
