On the complexity of scheduling checkpoints for computational workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
This paper deals with the complexity of scheduling computational workflows in the presence of Exponential failures. When such a failure occurs, rollback and recovery is used so that the execution can resume from the last checkpointed state. The goal is to minimize the expected execution time, and we have to decide in which order to execute the tasks, and whether to checkpoint or not after the completion of each given task. We show that this scheduling problem is strongly NP-complete, and propose a (polynomial-time) dynamic programming algorithm for the case where the application graph is a linear chain. These results lay the theoretical foundations of the problem, and constitute a prerequisite before discussing scheduling strategies for arbitrary DAGS of moldable tasks subject to general failure distributions.
RR-7907.pdf (786.79 Ko) Télécharger le fichier
hal-00680386 , version 1 (19-03-2012)
  • HAL Id : hal-00680386 , version 1
Yves Robert, Frédéric Vivien, Dounia Zaidouni. On the complexity of scheduling checkpoints for computational workflows. [Research Report] RR-7907, INRIA. 2012. ⟨hal-00680386⟩
116 Consultations
189 Téléchargements
