High order asymptotics for the electromagnetic scattering from thin periodic layers : the 3D Maxwell case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
This work deals with the scattering of electromagnetic waves by a thin periodic layer made of an array of regularly-spaced obstacles. The size of the obstacles and the spacing between two consecutive obstacles are of the same order $\delta$, which is much smaller than the wavelength of the incident wave. We provide a complete description of the asymptotic behavior of the solution with respect to the small parameter $\delta$: we use a method that mixes matched asymptotic expansions and homogenization techniques. We pay particular attention to the construction of the near field terms. Indeed, they satisfy electrostatic problems posed in an infinite 3D strip that require a careful analysis. Error estimates are carried out to justify the accuracy of our expansion
DeJo_Asymptotique3D.pdf (562.78 Ko) Télécharger le fichier
hal-00682358 , version 1 (25-03-2012)
hal-00682358 , version 2 (03-01-2014)
  • HAL Id : hal-00682358 , version 1
Bérangère Delourme. High order asymptotics for the electromagnetic scattering from thin periodic layers : the 3D Maxwell case. 2012. ⟨hal-00682358v1⟩
345 Consultations
303 Téléchargements
