Sensor Data Fusion for Road Obstacle Detection: A Validation Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Real-time obstacle detection is an essential function for the future of Advanced Driving Assistance Systems (ADAS), but its applications to the driving safety require a very high reliability: the detection rate must be high, while the false detection rate must remain extremely low. Such features seem antinomic for obstacle detection systems, especially when using a single sensor. Therefore, multi-sensor fusion is often considered as a mean to reduce this limitation. In this paper, we propose to use stereo-vision as a post-process to improve the reliability of any obstacle detection system, by reducing the number of false positives. Our algorithm, which is both generic and real-time con firms detections by locally using the stereoscopic data.
InTech-Sensor_data_fusion_for_road_obstacle_detection.pdf (1017.56 Ko) Télécharger le fichier
hal-00683751 , version 1 (29-03-2012)
  • HAL Id : hal-00683751 , version 1
Raphaël Labayrade, Mathias Perrollaz, Gruyer Dominique, Didier Aubert. Sensor Data Fusion for Road Obstacle Detection: A Validation Framework. Ciza Thomas. Sensor Fusion and Its Applications, in-tech / Sciyo, 2010, 978-953-307-101-5. ⟨hal-00683751⟩
295 Consultations
740 Téléchargements
