Grid Analysis of Radiological Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
Vincent Breton
  • Fonction : Auteur
  • PersonId : 917630
Yann Gaudeau
  • Fonction : Auteur
  • PersonId : 757476
  • IdRef : 112706266
Emmanuel Jeannot
Yannick Legre
  • Fonction : Auteur
  • PersonId : 917638
Grid technologies and infrastructures can contribute to harnessing the full power of computer-aided image analysis into clinical research and practice. Given the volume of data, the sensitivity of medical information, and the joint complexity of medical datasets and computations expected in clinical practice, the challenge is to fill the gap between the grid middleware and the requirements of clinical applications. This chapter reports on the goals, achievements and lessons learned from the AGIR (Grid Analysis of Radiological Data) project. AGIR addresses this challenge through a combined approach. On one hand, leveraging the grid middleware through core grid medical services (data management, responsiveness, compression, and workflows) targets the requirements of medical data processing applications. On the other hand, grid-enabling a panel of applications ranging from algorithmic research to clinical use cases both exploits and drives the development of the services.
germain-breton-etal-2009.pdf (3.95 Mo) Télécharger le fichier
hal-00683992 , version 1 (30-03-2012)
Cecile Germain-Renaud, Vincent Breton, Patrick Clarysse, Bertrand Delhay, Yann Gaudeau, et al.. Grid Analysis of Radiological Data. Mario Cannataro (Ed.). Handbook of Research on Computational Grid Technologies for Life Sciences, Biomedicine and Healthcare, IGI, pp.363-391, 2009, chapter 19, ⟨10.4018/978-1-60566-374-6.ch019⟩. ⟨hal-00683992⟩
1059 Consultations
337 Téléchargements
