A State Dependent Sampling for Linear State Feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2012
In this work, a new state-dependent sampling control enlarges the sampling intervals of state feedback control. We consider the case of linear time invariant systems and guarantee the exponential stability of the system origin for a chosen decay rate. The approach is based on LMIs obtained thanks to sufficient Lyapunov-Razumikhin stability conditions and follows two steps. In the first step, we compute a Lyapunov-Razumikhin function that guarantees exponential stability for all time-varying sampling intervals up to some given bound. This value can be used as a lower-bound of the state-dependent sampling function. In a second step, an off-line computation provides a mapping from the state-space into the set of sampling intervals: the state is divided into a finite number of regions, and to each of these regions is associated an allowable upper-bound of the sampling intervals that will guarantee the global (exponential or asymptotic) stability of the system. The results are based on sufficient conditions obtained using convex polytopes. Therefore, they involve some conservatism with respect to necessary and sufficient conditions. However, at each of the two steps, an optimization on the sampling upper-bounds is proposed. The approach is illustrated with numerical examples from the literature for which the number of actuations is shown to be reduced with respect to the periodic sampling case.
Automatica_-_Fiter_Hetel_Perruquetti_Richard.pdf (292.99 Ko) Télécharger le fichier
hal-00685345 , version 1 (04-04-2012)
Christophe Fiter, Laurentiu Hetel, Wilfrid Perruquetti, Jean-Pierre Richard. A State Dependent Sampling for Linear State Feedback. Automatica, 2012, 48 (8), pp.1860-1867. ⟨10.1016/j.automatica.2012.05.063⟩. ⟨hal-00685345⟩
361 Consultations
477 Téléchargements
