Maximum principle and bang-bang property of time optimal controls for Schrödinger type systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We consider the time optimal control problem, with a point target, for a class of infinite dimensional systems with a dynamics governed by an abstract Schrödinger type equation. The main results establish a Pontryagyn type maximum principle and give sufficient conditions for the bang-bang property of optimal controls. The results are then applied to some systems governed by partial differential equations. The paper ends by a discussion of possible extensions and by stating some open problems.
Loheac_Tucsnak.pdf (177.33 Ko) Télécharger le fichier
hal-00685359 , version 1 (04-04-2012)
hal-00685359 , version 2 (29-11-2012)
hal-00685359 , version 3 (16-04-2013)
  • HAL Id : hal-00685359 , version 1
Jérôme Lohéac, Marius Tucsnak. Maximum principle and bang-bang property of time optimal controls for Schrödinger type systems. 2012. ⟨hal-00685359v1⟩
339 Consultations
1026 Téléchargements
