GPU-based Real-Time Soft Tissue Deformation with Cutting and Haptic Feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Progress in Biophysics and Molecular Biology Année : 2010
This article describes a series of contributions in the field of real-time simulation of soft tissue biomechanics. These contributions address various requirements for interactive simulation of complex surgical procedures. In particular, this article presents results in the areas of soft tissue deformation, contact modelling, simulation of cutting, and haptic rendering, which are all relevant to a variety of medical interventions. The contributions described in this article share a common underlying model of deformation and rely on GPU implementations to significantly improve computation times. This consistency in the modelling technique and computational approach ensures coherent results as well as efficient, robust and flexible solutions.
pbmb10-fem-cutting.pdf (2.4 Mo) Télécharger le fichier
pbmb10-fem-cutting.mp4 (58.96 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00686056 , version 1 (06-04-2012)
Hadrien Courtecuisse, Hoeryong Jung, Jérémie Allard, Christian Duriez, Doo Yong Lee, et al.. GPU-based Real-Time Soft Tissue Deformation with Cutting and Haptic Feedback. Progress in Biophysics and Molecular Biology, 2010, Special Issue on Biomechanical Modelling of Soft Tissue Motion, 103 (2-3), pp.159-168. ⟨10.1016/j.pbiomolbio.2010.09.016⟩. ⟨hal-00686056⟩
855 Consultations
2125 Téléchargements
