First steps on asynchronous lattice-gas models with an application to a swarming rule - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Nazim Fatès
Vincent Chevrier
Lattice-gas cellular automata are often considered as a particular case of cellular automata in which additional constraints apply, such as conservation or spatial exclusion of particles. But what about their updating? How to deal with non-perfect synchrony? Novel definitions of asynchronism are proposed that respect the specificity of lattice-gas models. These definitions are then applied to a well-known swarming rule in order to explore the robustness of the model to perturbations of its updating.
boure2012-HAL.pdf (352.56 Ko) Télécharger le fichier
hal-00687987 , version 1 (16-04-2012)
hal-00687987 , version 2 (14-06-2012)
  • HAL Id : hal-00687987 , version 1
Olivier Bouré, Nazim Fatès, Vincent Chevrier. First steps on asynchronous lattice-gas models with an application to a swarming rule. [Research Report] 2012, pp.10. ⟨hal-00687987v1⟩
332 Consultations
262 Téléchargements
