Describing A Cyclic Code by Another Cyclic Code
A new approach to bound the minimum distance of $q$-ary cyclic codes is presented. The connection to the BCH and the Hartmann--Tzeng bound is formulated and it is shown that for several cases an improvement is achieved. We associate a second cyclic code to the original one and bound its minimum distance in terms of parameters of the associated code.
ZehBezzateev_DescribingACyclicCodeByAnotherCyclicCode_halIsitfinal.pdf (135.92 Ko)
Télécharger le fichier
