Analysis and Design of Equilibrium Points for the Cell-Transmission Traffic Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dominik Pisarski
  • Fonction : Auteur
  • PersonId : 924452
The problem of equilibrium points for the Cell Transmission Model is studied. The structure of equilibrium sets is analyzed in terms of model parameters and boundary conditions. The goal is to determine constant input flows, so that the resultant steady state of vehicle density is uniformly distributed along a freeway. The necessary and sufficient conditions for the existence of one-to-one relation between input flow and density are derived. The equilibrium sets are described by formulas that allow to design a desired balanced density. A numerical example for the case of a two-cell system is presented.
EQ_SETS_CONTROL_06_30.pdf (160.79 Ko) Télécharger le fichier
hal-00691522 , version 1 (26-04-2012)
hal-00691522 , version 2 (14-06-2012)
hal-00691522 , version 3 (30-06-2012)
  • HAL Id : hal-00691522 , version 3
Dominik Pisarski, Carlos Canudas de Wit. Analysis and Design of Equilibrium Points for the Cell-Transmission Traffic Model. ACC 2012 - American Control Conference, Jun 2012, Montreal, Canada. ⟨hal-00691522v3⟩
280 Consultations
509 Téléchargements
