A generic framework for n-protocol compatibility checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2012
Service-Oriented Computing promotes the development of new systems from existing services which are usually accessed through their public interfaces. In this context, interfaces must be compatible in order to avoid interoperability issues. In this article, we propose a new framework for checking the compatibility of n service interfaces. Our framework is generic, in the sense that it implements several compatibility notions useful for different application areas, and extensible since new further notions can easily be incorporated. We consider a service interface model which takes behavioural descriptions with value-passing and non-observable actions into account. Our compatibility checking framework has been fully implemented into a prototype tool which relies on the rewriting logic-based system Maude.
DOS-scp09.pdf (428.86 Ko) Télécharger le fichier
hal-00694561 , version 1 (05-05-2012)
  • HAL Id : hal-00694561 , version 1
Francisco Durán, Meriem Ouederni, Gwen Salaün. A generic framework for n-protocol compatibility checking. Science of Computer Programming, 2012, 77 (7-8), pp.870-886. ⟨hal-00694561⟩
225 Consultations
260 Téléchargements
