A Generalized Kernel Approach to Structured Output Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hachem Kadri
Mohammad Ghavamzadeh
  • Fonction : Auteur
  • PersonId : 868946
Philippe Preux
We study the problem of structured output learning from a regression perspective. We first provide a general formulation of the kernel dependency estimation (KDE) problem using operator-valued kernels. We show that some of the existing formulations of this problem are special cases of our framework. We then propose a covariance-based operator-valued kernel that allows us to take into account the structure of the kernel feature space. This kernel operates on the output space and encodes the interactions between the outputs without any reference to the input space. To address this issue, we introduce a variant of our KDE method based on the conditional covariance operator that in addition to the correlation between the outputs takes into account the effects of the input variables. Finally, we evaluate the performance of our KDE approach using both covariance and conditional covariance kernels on two structured output problems, and compare it to the state-of-the-art kernel-based structured output regression methods.
RR-7956.pdf (321.74 Ko) Télécharger le fichier
hal-00695631 , version 1 (09-05-2012)
hal-00695631 , version 2 (15-07-2015)
Hachem Kadri, Mohammad Ghavamzadeh, Philippe Preux. A Generalized Kernel Approach to Structured Output Learning. International Conference on Machine Learning (ICML), Jun 2013, Atlanta, United States. ⟨hal-00695631v1⟩
518 Consultations
441 Téléchargements
