A Monitoring Approach for Dynamic Service-Oriented Architecture Systems
In the context of Dynamic Service-oriented Architecture(SOA), where services may dynamically appear or disappear transparently to the user, classical monitoring approaches which inject monitors into services cannot be used. We argue that, since SOA services are loosely coupled, monitors must also be loosely coupled. In this paper, we describe an ongoing work proposing a monitoring approach dedicated to dynamic SOA systems. We defined two key properties of loosely coupled monitoring systems: dynamicity resilience and comprehensiveness. We propose a preliminary implementation targeted at the OSGi framework.
Génie logiciel [cs.SE]
