Dexpler: Converting Android Dalvik Bytecode to Jimple for Static Analysis with Soot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces Dexpler, a software package which converts Dalvik bytecode to Jimple. Dexpler is built on top of Dedexer and Soot. As Jimple is Soot's main internal representation of code, the Dalvik bytecode can be manipulated with any Jimple based tool, for instance for performing point-to or flow analysis.
article.pdf (208.53 Ko) Télécharger le fichier
hal-00697421 , version 1 (15-05-2012)
hal-00697421 , version 2 (30-01-2013)
Paternité
Alexandre Bartel, Jacques Klein, Martin Monperrus, Yves Le Traon. Dexpler: Converting Android Dalvik Bytecode to Jimple for Static Analysis with Soot. ACM SIGPLAN International Workshop on State Of the Art in Java Program Analysis, Jun 2012, Beijing, China. pp.27-38, ⟨10.1145/2259051.2259056⟩. ⟨hal-00697421v2⟩
435 Consultations
3703 Téléchargements
